I have a Renogy 200W suitcase solar that has 20A PWM charge controller (12v system). Controller has max solar voltage 26V, max battery voltage 17V rated current 20A battery start charging voltage 3V. I have used this to connect to my RV batteries with Lead Acid 6V batteries in series and works well
Just purchased AC200Max which accepts solar input 10 - 145V.
Problem seems to be that the AC200Max wont turn on DC input port with less than 10V and the Renogy wont send voltage if it senses less than 3V in battery. In this condition I cannot even change battery type on the charge controller as it goes into an error condition for battery under voltage
How do I make this work?
Mike
