Hi, what will happen if I install an ac200max in a car/van ?
I’m located in a warm country and temperatures can overcame 45deg centigrade
when car parking and overcame 40deg when operating.
Those temperatures appear as maximum storage and operating on the ac200max specs.
It is recommended to secure it when using in your van.
When using it in the car, pay strict attention to the temperature (Within the temperatures permitted by the AC200MAX manual), do not use it when the temperature is too high, avoid direct sunlight, and do not charge or discharge it unattended. It is not recommended to use it while driving, as the bumps may cause the socket to loosen and have poor contact.
