Hi can anyone point me in the right direction? I have a AC200Max it will not charge when I plug the transformer into 110v outlet. It shows on the front display 0 input 0 out. I checked the voltage out of the transformer power supply read 59V dc. I plug the transformer into the B230 and it starts charging it fine so I think the power supply is ok.
Hi @TimD, We assume that you are saying the T500 cannot charge the AC200MAX, is that correct?
Please confirm the current battery level of the AC200MAX. We suspect it might be nearly fully charged, which temporarily halts the charging process. We suggest discharging the AC200MAX a bit and then trying to charge it again.
