AC200MAX loose AC ON Setting after restarts with Solar Power when it was Empty. 0%
Second Thing when AC200MAX was empty 0% and restarts with Solar Power the B300 still OFF.
Always you have to switch ON B300 and Set AC ON!
@bluetti_mailderschnubblerde
AC200max does not have the function of automatic battery pack activation.
After the AC200Max is powered off without power, the PV will activate the machine after charging. When the machine is turned on, you need to turn on the B300 manually in order to re-communicate on.
I understand, but Why i have to switch The B300 ON and Set the AC ON on the Powerstation manualy? It sucks.
Everthings works Fine but i have to Switch this manualy. Last Time i run out of power because the B300 sleeps! No AC till i Switched it ON!
Everthing you Can Save in The Menu ,But AC ON and reactivate Battery Pack After Solar Power Starts?
The machine will turn off the AC when it runs out of power.
And after re-charging, it is necessary to turn on the AC again when carrying a load
@BLUETTI Your reply just above is interesting. Are you saying that there is no automatic restart?
The user manual says there is automatic restart: "When the battery level drops to 0%, the DC and AC output will automatically turn off, and ONLY when the battery power is recharged to more than 5%, the DC and AC output will be turned on again.
My manual says the same under “13. EXAMPLES OF LOADS”, section (4). I haven’t tried it myself, but I’m wondering if it’s a tranlation issue and instead of “will be turned on again”, it should have been “can be turned on again”. I agree with others, really wish it was “will” and not “can”.
BLUETTI has not set up a function for automatic rebooting. Only PV input can activate the machine, but AC still needs to be manually turned on. May I ask if you saw the term “automatic reboot” in the user manual for AC200MAX?
Thanks, @BLUETTI.
It was due to the statement in the user manual ^^: “ONLY when the battery power is recharged to more than 5%, the DC and AC output will be turned on again”.
I recommend that this be changed to “DC and AC output can be turned on again”.
Your feedback has been received and I will pass it on to the manual writing team. :)
