As I understood the max dc power available at the AC200Max is 12V/30A = 360W.
Could a grid tied inverter be connected to the 53V AC200max Batterie expansion port to get more power out? What is the max current allowed to be drawn ?
Thanks for your help - Franz
Hi @Franz , based on your question, we have consulted the relevant engineers for you.
They replied: You can not do so, the battery extension port can only be connected to the battery pack can not be connected to the inverter
No, you cannot. The Bluetti battery expansion port has local intelligence that communicates between the power station and the B series of batteries. The port has two large DC contacts rated at 90 A for power transfer, and eight smaller contacts for the intercommunications between the power station and the battery. Through this communications your power station can charge, monitor, and control each battery. This is also why you cannot attach any other battery, either a basic string of cells in series or a battery from a different manufacturer to the power station, or an inverter to the battery.
Thank you for the info. I checked the connector and found some additional wires in addition to the large DC ones which are obviously used for control and communication with the B230/B300 battery expansion. On the other hand there is a two wire P090D to XT4 cable available from Bluetti for battery expansion which should allow DC connection without control and monitoring as well.
A very good news for you (and me) Exclusive: Bluetti announces micro solar power plant plus off-grid system EP800 | nextpit
In an interview with nextpit, Bluetti revealed that they will be launching a micro inverter this year that not only feeds the electricity from connected solar panels into the house grid, but can also temporarily store the excess energy generated in a battery. This will include the ability to use smart sockets and other tools to vary the feed dynamically into the home grid to optimize the self-consumption of solar energy.
Some specifications on the future “solar balcony system” from bluetti with an external grid-tie inverter
https://www.chinahandys.net/bluetti-ifa-2023-balkonkraftwerk/
Sorry, the latest news : Bluetti confirms that the solution is not compatible with ACs (AC200max etc…) and expansion batteries B230, B300. This is only compatible with the new B210s.
