ac200max dsp firmware update failing
I have a bluetti ac200 max i purchased July 11 2023 on amazon. I charged it I updated firmware and put it in a closet, now I pull it out and using the app I checked for firmware updates and found a dsp update available. I tried to install it, the fans kicked on like i have read about but within seconds i am getting an error on app says upgrade failure communication disconnected please check the connection. then i get an alarm on the ac200max that says 033. spi communication error. please help.
i have tried uninstalling app clearing the cache power cycling devices. i dont have another cell phone to try the blue tooth with,i am using samsung galaxy s22 ultra
ac200max
serial 2237001432111
firmware ver
arm v4030.1
dsp v4005.07 trying to upgrade this to v4005.08
bms v1017.03
hm1 v6023.11
Hi @joe04wj, Based on your description, we guess it is a failed firmware upgrade. We recommend performing the upgrade again.
Please disconnect the AC200MAX from all power sources, loads, and battery packs
Keep your phone as close to the device as possible, and set the screen timeout to ‘Never’.
If using Wi-Fi, try switching to mobile data as this often improves connection stability
If the update still fails after these steps, don’t worry - your unit is well within its warranty period. We can arrange for it to be serviced at our facility, where our technicians will complete the upgrade for you.
Feel free to contact us if you need further assistance.
I just tried it again and I get that communication error within 5 to 7 seconds. How do I get this resolved? Who do I contact?
Hi @joe04wj, We believe this issue requires contacting customer service to arrange for a warranty claim. Could you please contact us via private message and provide your order details? We will then make the necessary arrangements for you.
