Ac200max charging
My t500 charger stopped working for my AC200Max and new ones are currently out of stock. Any ideas on how to get a new one or a different solution? would the T200S Adapter work to charge the ac200max. I realize its only 200 watts but it is better then nothing if its not a good solar day. Any input is appreciated. Thanks!
It’s fine through the PV charging port (An additional adapter is required), but not through the adapter charging port.
Any specific reason? Please provide as much information as possible so that our @BLUETTI_CARE team can better assist you.
An adapter like this : dc7909 female to mc4
https://www.aliexpress.us/item/3256804393362457.html
Hi @bdbrook1008, We’re not sure which country you’re located in. We recommend contacting the customer service team for your specific region to check if there is any refurbished stock available in the local warehouse.
Does that help?
