I sent the following email to [service@bluettipower.com] on 1/15/23:
To whom it may concern:
I purchased my AC200Max and PV200 panel directly from Bluetti online on or about 5/22/2022. Order number Bluetti - US26731. Items were delivered on or before 5/31/2022. I used the AC200Max several times in my RV, without issue, with the last time being in mid-October, at which time I fully charged it, turned the unit off, disconnected all charging ports, and left it in the RV. It did get below freezing a few times, but all within the specifications listed for storage. I live in Roanoke, VA so it’s not that cold here.
I brought the unit into my home two weeks ago in preparation for severe weather and when it powered on the SOC was only at at 89% and then continued to fluctuate between 85% and 95% each time I powered it off and on. When I attempted to charge it, it “charged” to 100% in less than 5 minutes, then fluctuated again. None of these are expected readings or behaviors.
After some research in the forum, I attempted to reset the battery meter by fully discharging, at a steady state, until it powered off, and then, immediately, fully recharged via an AC12OV outlet. Had the same issue with SOC at 89% immediately after powering back on, so did the whole discharge/charge cycle again without successful resolution.
There is no indication of a firmware update in the app as far as I can tell. I’ve attached a screenshot of the unit SN and firmware versions for reference.
1/21/23: Reply from CS | “Sorry for the late reply and sorry for the problem. This problem can be solved by upgrading the latest firmware. Can you please provide your serial number which is with the QR code? So I can ask our technician to push the latest version to you.”
1/21/23: I resent the SN
1/25/23: No reply; I sent the following: “Following up on this. What are next steps - how and when do I load the updated firmware? The delay in response is frustrating”
1/27/23: Reply from CS | “Sorry for the late response and sorry for my negligence. I have already provided your serial number to our technician. They will push the latest version of the firmware to you today. Please wait with patience.”
2/3/23: I still have not received a firmware update and sent a follow-up inquiry.
I also called the customer service number I found on this site: 702-463-4792 but got their voicemail explaining how busy their customer service is, to have patience etc etc. In the end I couldn’t leave a voicemail, as instructed, because the mailbox is full! Really??? I’m extremely frustrated with this situation and not sure where else to turn. Considering how much I spent on this system (gen and panels), this is unacceptable imo.
Has anyone had experience in receiving a firmware update for this scenario? If so, did it resolve the issue and have you had the issue again, since the update? Not sure if this is worth the headache and thinking of trying to return the unit - another headache, likely, but that’s alot of money down the drain.
