AC200Max as a battery ?
Hi all! can I use AC200Max as a extra batery for another AC200Max ? I mean to connect together like an extra batery like a B230 or B300 .
You mean plug the AC power charging cord into the output of another one? Don’t see why it won’t work but it won’t be very efficient. Would be better if you plugged your loads into both of them normally, unless you have just one big power hungry load, like running an air conditioner.
Sorry, hosts are not allowed to connect to each other unless the machine supports split-phase mode.
