AC200MAX AC auto ON onstart
hi,
  1. I have AC200MAX and I wanna to configure AC to be ON with start, is it possible?
I have 3 times a day powerOFF and each time i need to on AC… and it would so cool if I can configure it always ON.
  1. Also charger AC200MAX is always working (when plugged into 220) and noisy. Could it off when AC200MAX is chargered ? In that case after finishing charging it will off and no noise.
tnx in advance!
Hi @Staller,
No this isn’t possible, and it’s for safety reasons. You can however look into disabling ECO mode (as described in the user manual, page 42):
ECO Mode: When it’s on, the AC power will automatically turn off over 4 hours
low (≤50W) or no load to save power drain.
This of course in case you can afford keeping the invert on all day.
Neither I’m afraid. Maybe use a smart plug to create charge schedules?
ah ((
but tnx for quick reply
Yes it works, with smartlife/tuya compatible smartplug for example : you can program the scenario in smartlife: if the power passing through the socket (to power the t500 adaptor ) is less than 50w, then turn off the socket…
Good point. I just meant the features @Staller asks isn’t built either in the unit or in the power brick.
You are right, I edited my answer above to avoid misunderstanding:
the t500 adapter does not know how to put it on standby and stop its fan… You need to add an external smartplug, as Decerto suggests, to be able to stop the t500 automatically when it has finished loading.
big tnx! will buy smartlife/tuya compatible smartplug for my 2nd question.
Hi @Staller, This is indeed a very good suggestion, and we have already passed it on to the product development team.
For the AC200MAX, this is a technical challenge and may be difficult to implement.
However, we will try to incorporate this feature into new products.
