AC200L solar panels configuration?
I’m new to the solar topic and I’m confused on how to connect my solar panels to get the best of my AC200L. I have 16 solar panels (100 watts, 21 voc and 5 amps). I was thinking on use 12 panels in a 4 series of 3 panels. That would be ok or should I use another configuration? Thanks in advance.
To maximize production, you might consider strings of 5 panels, with 3 strings in parallel.
  • It’s always best to go as high as 90% of the max Voc of your generator
  • In parallel, each string must be identical
  • Each string should only be made of identical panels
That motivates me suggesting 5S3P.
Ok, thanks for your help.
