AC200l run my 12 volt rv lights
Wil Bluetti’s DC run my 12 volt lights while plugged into my motorhome convert/charger panel if I don’t have coach batteries anymore?
I’m trying to eliminate the coach batteries and only run of the AC200L. I know if I have coach batteries the AC200L will try to charge them via: my converter/charger it’s plugged into.
Hi @Rworell
The AC200L does have a 48V RV Output that can be used with the D40 to charge a 12V Battery and there is a cigarrete Lighter port than provide stable 12V.
A Powerstation cant replace a Vehicles Starter Battery.
Does this answer your question?
