Hi there,
I recently received an AC200L and PV350 solar panel. I tested the solar panel in perfect weather conditions (no clouds, no shade, direct sunlight 75 °F) and am averaging around 150w solar input. I have verified that the AC200L is set to PV input, all plugs are tight, I turned it on/off and unplug/plug everything. My understanding is that I should be getting 250+ watts or ideally 300+ watts in these conditions. I checked the voltage and it’s around 24v on average (according to the app). I Also began charging the AC200L when it was at 55%.
Would anyone happen to know if there is anything else I can check to determine if the PV350 panel is working as expected? Or maybe there is another setting I need to change on the AC200L? (I didn’t see anything in the manual)
Any ideas or guidance would be appreciated. I’m hoping to figure it out. Luckily I still have 30 days to return.
