I own a AC200L (US) and have two topics, one is the common PV relay clicking at sunset/sunrise and the other is the fan turning on for 25 seconds every 60 seconds or so.
Relay: I have read in various topics about this and would like Bluetti-Care push the DSP version that will reduce the relay switching frequency to me, my info is below. Now more urgent since I read the relay only survives 100,000 switches, comment by Bluetti I believe, this is less than the battery by a mile.
DSP: v2098.10
BMS: v1043.11
SN: AC200L2349000477638
Fan Topic: Turns on for 25 seconds every 45 to 60 seconds, (does this all day/night). its the low fan speed, so not terribly annoying, but I find it strange. I do understand the inverter is on and needs to keep check on Temp, but seems a bit too much. Here is my setup:
Customized UPS 23% to 95% SOC with 23 hours off peak and 1 hour off-peak scheduled at night to get some juice from the grid! I have both PV and GRID connected, but only PV is charging (except for that 1 hour) and the battery provides power to my devices (not the grid - no bypass - Grid stays on 0w on peak hours).
System is on 24/7, on AC discharge powering various devices including Lights and fridge. The away from home discharge is between 30 and 80W per hour, and when at home between 100 to 200W per hour. At time of this writing the discharge is at 35W (on purpose for testing) and even with that low discharge fan turns on every 45 seconds for 25 seconds.
I also have a B210 connected to the AC200L with no AC charging or PV connected to the expansion battery and no discharge devices connected, except AC200L.
Perhaps it stated when I updated both the AC200L and B210 BMS and DSPs, since I don’t recall having noticed the Fan prior!
I have placed two cooling fans (desktop type) on top of the AC200L to see if it helps keep the temp controller happy… so far no change.
@BLUETTI_CARE let me know your thoughts about Fan and if there is an update that can be pushed. Re. Relay please push the Relay update!
Thanks a Bunch
P.S.: I have 3 different Bluetti’s AC70S, AC180 (very loud fan) and the AC200L… overall happy customer!
