@BLUETTI_CARE : Why is the AC200L limited to about 850W of input power from PV (DC input) after ~1 hour running 1.2kW?
Below is a chart of the DC input power the AC200L measured on its DC Input from today. It slowly increased as the sun came up, then maxed out at 1.2kW, which seems normal. However, at about 12:50PM, the DC input power suddenly dropped down to about 840W.
The chart below shows sunlight brightness and there was no significant (or long) decrease in sunlight at that time. There were a few clouds, but they moved out and the sun came back. But, the AC200L didn’t.
Ambient temps near the AC200L stayed around 22 for the entire day, so it shouldn’t be overheating.
Though, to test this, a few days ago, I did point a fan at the air intake on the AC200L and cranked up the fan to high. It didn’t make a difference with this issue.
At that time the combined battery SOC was around 50%, so that shouldn’t be an issue.
Below is the battery pack SOC breakdown. Green: AC200L internal battery, orange: B300 battery connected directly to the AC200L, blue: a second B300 connected to the first B300, which connects to the AC200L.
Note that the SOC randomly jumps up when it reaches closer to 100% I am not sure what causes this, but this is an issue for another day. I have tried calibrating one of the B300 batteries (full charge / discharge 2 times), but it didn’t make a difference, so I didn’t bother with the other B300.
both the AC and DC outputs at around this time were nearly 0W, so this should have little impact on anything.
The DC input voltage as measured by the AC200L stayed well under the 145V max, so this shouldn’t be an issue. Though, it is interesting that the voltage went up a bit near 12:50PM. Don’t worry about the yellow dashed line. That is a line I added to the chart to show the voltage at which the PV input relay clicks on / off.
I have the AC200L set to “turbo charge” mode. I tested in standard mode and it didn’t make a difference. Note that the AC input on the AC200L is not plugged in. So there was no AC input power during this entire day.
I am using 1.5kW of solar panels (which I know is technically over spec), but the theoretical PV open circuit voltage is 125V, so this should not be anywhere near the danger zone of 145V.
One interesting thing I noticed is that if I disconnect the PV array from the AC200L (shut off the main PV isolation switch), wait 20 seconds, then switch it back on the AC200L will magically go back to 1.2kW (this was done on a previous day, hence it is not shown on the charts). However, after some time, it will fall back to about 840W.
I have recently (within the last week) checked for firmware updates for the AC200L (and B300), but there were none.
Do you have any thoughts as to why this would happen? Is my AC200L defective? Is there a firmware update that could improve this situation?
If you need any additional information, I can try to provide it, so let me know.
