AC200L doesn't display AC load with up 100 Watt
@BLUETTI_CARE
I have an AC200L power station. When I turn on the AC and connect a load of 50-70W (verified with a separate watt meter and checked against the device’s specifications), the station’s screen shows 50-70W for one second and then displays 0W for the AC load. Sometimes, no values appear even for a second—just zero. At the same time, I notice that the remaining discharge time changes. However, if the load is 100W or more, the values are displayed on the screen correctly. Could you please clarify if this is normal operation for the station or a malfunction? All updates in the app have been completed.
Hi @Dmytro2, When the AC200L is connected to low-power devices, it will not display the output power. This is due to the low power level, which can lead to sampling errors.
This does not affect usage at all. Based on your description, when powering devices with a load above 100W, the AC200L displays correctly, which indicates that the AC200L is functioning properly.
