AC200L + B230 problem
In late 2022 I purchased the B230 expansion battery as a backup to my AC200P system. That B230 charges the AC200P fine using the appropriate cables.
I recently purchased the AC200L and I hoped that it would also work with this AC200L. I first did a bunch of charge and discharge tests with the AC200L by itself and everything is working fine.
I then independently discharged this AC200L down to 70%, and fully charged the B230 to 100% using an AC adapter power brick.
I attached the two units through their battery expansion ports using the P090A to P090A cable making sure to switch both ends to LOCK with a click sound. After a few seconds the AC200L display reads 85% and the expansion battery detection light (top left corner) appears on the display. 85% is the average of initial AC200L SOC (70%) and initial B230 SOC (100%), so I thought the connection was good.
I then turned on AC output on the AC200L and plugged in a 700W dehumidifier unit. Turning on the dehumidifier shows around 700W AC output on the AC200L screen but the AC input reads ZERO. Running the dehumidifier for a while with the AC200L + B230 connected, and then disconnecting them, shows that ONLY the AC200L has been drained below 70%, while the B230 is still 100% (based on its indicator lights). This indicates that there was no actual charge transfer and/or charge equalization between the two units.
What is the problem here? Do I need to download the app and do some kind of firmware or BMS update or something? I thought the P090A to P090A cable was a “plug and play” instant detection and charge/discharge transfer between the B230 and AC200L ?
To help resolve the issue, please follow these steps:
  1. Check if the BMS firmware version is the latest. If it’s not, please upgrade the BMS firmware in the app.
  2. Perform a charge and discharge cycle by fully depleting the battery and then recharging it to full. Please ensure that no load devices are connected during the charging process.
    If you have any further questions or need assistance, feel free to reach out!
