Is there a way to connect the AC200L to a 12v DC fuse box in campervan to run 12V fridge, lights and other item,s? I thought the D40 was able to do this with the 48Amp DC connection but I read int couldn’t be the specs for the D40 that it couldn’t be directly connected to a fuse panel. Please clarify.
I just received a D40 and it does indeed output 12 volts regulated to a fuse panel if desired. I have had issues with it starting items with the D40 that will start and run when connected to the cig socket on the AC200L. (small air compressor, 3 very small inverters) I was able to pull a steady 21 amp load with no problems and completed an overnight 12 amp load which worked fine. At this point I would suggest you wait a bit more before going down the D40 route as it does not seem to be able to perform its intended function at this point.
