How do I connect (2) SP200L Bluetti Panels to my AC200L.
Went camping after changing the unit (AC) and then tried to set it up and only have (1) cable to attach the panels to the AC200L.
What other parts/cables do I need?
HELP…
HELP…
You should be able to wire the panels in series. This means daisy chaining them together. Connect one wire each from the panels together, then connect the cable from the AC200L to each of the remaining leads.
You always want to make sure the added VOC or OCV never exceeds the VOC rating of the unit, but in this case the OCV of 24.62V of the two panels (near 50v) is well below the limits of the AC200L, which is 145V.
Thanks for the reply! I went onto YouTube and found the answer as well. The extra details you included are valuable info!
