@ Bluetti admin is the 30 amp AC charging accessory cord for the AC300 compatible with the new AC200L. Basically if I order that cable will it work on the AC200L?
@Scott-Benson
Hi Scott, After confirmation with tech team, AC300 30A cable is not compatible with the AC200L, as the interface specifications are different.
Can you tell us when any of the accessories will be available for the AC200?
