Привет, у меня та же проблема: мой Bluetti полностью выключается, когда отключается электричество. Приходится включать его вручную, и тогда всё работает нормально. Говорят дело в прошивке
Hi @BLUETTI_CARE this user have problem with AC180P.
It turns off when the power supply is lost. And you have to turn it on manually, then everything works fine.
Hi @DrLee, yes, this is a firmware problem.
Now I have applied to upgrade your system to our IT department. If the new firmware is available, they will complete the push within 1 working day.
Please upgrade the firmware next Monday. Please do not load any device when upgrading it.
Thank you for @Tony_MVP’s kind reminder.
@DrLee, I assume that responses will come a little sooner here in this English forum if you write your question in English.
I myself cannot read Russian, Ukrainian, … (?) and don’t want to run every post through a translation program just to see if I could respond …
