Hi @Dmitro_L, you are welcome.
We all hope everything goes smoothly.
hello
Can u send me updates for my ac200pl
AC200PL2434000214301
IOT v9041.10
ARM v2140.70
DSP v2130.70
Hi @BLUETTI_CARE,
I would like the “System Switch Recovery” feature as well. I need my AC200PL to automatically turn AC on after the grid is restored. My details are:
AC200PL2501002188787
IOT: v9041.10
ARM: v2141.07
DSP: v2098.22
BMS: v1056.03
Hi @BLUETTI_CARE, і didn’t know where better to write. I wanted to ask if it is possible to create widgets for your application in the future? I have Ecoflow and it is very convenient to manage thanks to the widget. I also have Apex 300 and AC2P, and the application now much more better, but there are still no widgets.
Hello!
Thank you for your feedback. We’re glad to hear that you find our app has improved significantly. Regarding the widget feature, could you please specify what kind of widgets you would like to see? If you could provide more details about your needs, we will forward your suggestions to our technical team.
Thank you!
Hello, I have registered your firmware upgrade. Please wait patiently.
Hello, what problems are you currently experiencing with your device? You can check in the device’s settings page to see if there is a firmware upgrade available. If so, you will need to bind the device to upgrade.
@Tony_MVP @BLUETTI Can you please move request about widget as new topic in the APP section - BLUETTI APP - BLUETTI Community? I’m sure there will be a lot of discussion there, I will add my vision too a bit later. But here is definitely a bad place to start it, in very specific firmware-related topic.
Hello, i have old firmware and cant update it ( no actions avaliable)
Hello, I have registered your inquiry about whether there is a new firmware. Please wait patiently.
@BLUETTI Thank you. I am not yet seeing the new firmware. I see in this forum that it usually takes 24hrs or so for firmware to be pushed to us so I will wait and provide feedback.
and bms have also no updates, i mean icon is present but when i open it - it tell i have last version firmware
Hello, if everything is working fine, then there’s no need to update.
Hello, do you mean you’ve enabled the system switchover recovery function, but the AC isn’t automatically turning on? The system switchover function can be found in the device’s specific settings.
@BLUETTI Hi. I waited after 24hrs for the firmware to be pushed to me but I have still not received it. So I am unable to select the “System Switchover Recovery Function”.
So currently when my battery dies after the grid is down and the power returns, the AC and DC outlets on my power station remains off even when the battery has been charged to 100%.
Can you send me the " System Switchover Recovery" firmware to me?
IOT: v9041.10
ARM: v2141.07
DSP: v2098.22
BMS: v1056.03
same, me. to. !!!1!!!
Hello, your firmware is already up to date.
Hello!
I apologize for the wait. I have urged the technical team to update the firmware for you. If you have any other questions, please feel free to let us know.
Thank you!
