AC180P upgrade request for auto restore AC/DC after power restore
@BLUETTI_CARE Im upgrade to the newly released app today, but the System Switch Recovery function option is not appear on this device AC200PL sn AC200PL2435000094621.
Hello, team Bluetti.
Can I get a new firmware for my AC180P?
AC180P2444000900529
ARM v2125.03
DSP v2126.03
Hi @alexsav, your firmware is already the latest version.This function is enabled by default. Please discharge all the power and test if it works first.
Please note that AC output will only activate when the battery’s level more than 5%.
  1. When grid power is available, the output settings will resume as soon as the battery reaches 5%.
  2. When grid power is unavailable, the output settings will only resume if the battery reaches 5% and the output has remained off for at least 30 minutes.
Hi @Serhii_ua, thank you for contacting us.
I have applied to upgrade your system to our IT department. They will complete the push within 24 hours.
@BLUETTI_CARE i have bluetti app 3.0.5 but i can’t see switch system recovery options anywhere and the app tell me the firmware is updated.
My AC200L:
IOT 9041.12
ARM 2131.05
DSP 2140.13
AC200L2402002831672
Regards,
Luigi
@BLUETTI_CARE same issue as highlighted in the attached thread, plus an issue with grid self adaptation been incorrectly changed to 120 volts when it should be 230 volts.
@BLUETTI_CARE Hi! Also i have a Bluetti AC300 and he has a next problem: incoming grid voltage is lower then 180V AC and bluetti cant charging? Can you apply new version of firmvare with low adn hight incoming voltage regukation? Bluetti ac300 s\n AC300223100524784, IOT v9014.10, ARM v4037.05, DSP v4036.02. Thanks!
I would like the “System Switch Recovery” feature as well. I need my AC200PL to automatically turn AC on after the grid is restored. My details are:
AC200PL2412000137160
IOT: v9041.10
ARM: v2140.05
DSP: v2130.13
BMS: v1056.03
Hi @luigi_tomaselli, thank you for contacting us.
Hi @alexsav, we would like to help you.
Please note that the SN code consists of 13 digits after the model name (AC300). The SN code you provided only has 12 digits, so it appears incomplete.
Please send us a screenshot of your SN code interface so we can confirm the correct SN and apply for the new firmware push for you.
Hi @vovichv, thank you for getting in touch with us.
unit upgrade and now i can see advanced options for system switch recovery, unfortunately enable the option Is not working, It remain disabled (i already rebooted the unit and used the 88888888 password).
Regards,
Luigi
Hi @BLUETTI_CARE ! This is AC300 SN code: AC3002231000524784
Hi @alexsav, thank you for your update.
Hi @luigi_tomaselli, we have forwarded your issue to the technical department, and they have pushed the latest firmware to you.
Please test after updating, and we look forward to your further feedback.
@BLUETTI_CARE Good afternoon! I inherited a Bluetti AC300 device, AC3002231000524784. It turns out that it is linked to the previous owner’s account. How can I unlink the device?
Hi BLUETTI_CARE,
unfortunately when i try to update ARM fron 2131.07 to 2131.08 i get this error: “download non riuscito” .
Already rebooted the unit and the app.
Regards,
Luigi
We have unbound the device as requested. You can now register and log in.
I hope it does help.
Hi @luigi_tomaselli, we have pushed the firmware update again. Could you please try upgrading once more?
Please make sure your phone is close to the AC200L to maintain a good signal.
We look forward to your feedback.
It did not work, same error (phone connected to wifi or via LTE):
Regards,
Luigi
