AC180P turns off randomly
@Yaroslav Let me check with our technicians. If I get any update, I will let you know ASAP.
I have been testing the new firmware for a couple of days. And it seems I have found steps to reproduce another bug. Now, everything works correctly at 100% charge. But when the battery discharges to 99% with the device connected to the power grid during the switch to charging mode, the device shuts down.
Steps to reproduce:
  1. Charge to 100%.
  2. With the grid, wait until the battery discharges to 99% and the device tries to switch to charging mode. (At this moment, the device shuts down completely)
    AC180P2349001578074
    ARM v2089.02
    DSP v2088.03
@okyesanap There is another new firmware, please have a test. Looking forward to your update.
@BLUETTI_CARE Thank you! Received the update. Will write a report in a few days - on Friday-Saturday.
I have the same problem:
AC180P2348000993279
ARM v2089.02
I have the same problem on my device:
SN: AC180P2349002018775
ARM: v2089.02
DSP: v2088.02
BMS: v1039.01
my post with details
@Jinx1991 @Grigoriy The new firmware will be pushed to your AC180P.
@BLUETTI_CARE I have been testing for 2 days. My grid sometimes drops to values when the device stops charging. And even in this mode, there was not a single shut down. So I can say that the bug which was at 99%-100% charge was fixed. Well done!
@okyesanap Thank you so much for your update.
Hello, I have the same issue.
SN: AC180P2349000435621
ARM v2089.02
Could you please sent the new firmware to my device ?
Hello, I have the same problem as well. Device turns off randomly + doesn’t work as an UPS when electricity in the apartment shuts down, could you please send me a new firmware with the fix? Thank you
SN: AC180P2349001064502
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
After update to DSP v2088.04 problems gone and it is working fine, thanks!
Hello, I have the same issue. Could you please send me a new firmware with the fix? Thank you
SN: AC180P2348001002962
ARM: v2089,02
DSP: v2088,02
BMS v1039,01
@mykolasus @retrogott @Vlad1 The firmware will be pushed in 24 hours.
Hey, could you also push new 04 firmware to me? Thanks!
AC180P2349000518238
ARM: 2089.02
DSP: 2088.03
BMS: 1039.01
@onefoursix OK, we will.
I’m expecting new firmware too. Thx a lot.
AC180P2349000731658
ARM: 2089.02
DSP: 2088.02
BMS: 1039.01
Another question - When all users will be able to get actual firmware?
Hey, I have the same problem- my Bluetti completely shuts down when electricity goes off. I have to turn it on manually and then all works fine. Pls push this new firmware for me too
AC180P2349001626912
ARM 2089.02
DSP 2088.02
AC180P2349000913774
ARM: 2089.02
DSP: 2088.02
@moni @Sergeylitv The firmware has been pushed, please check.
When a firmware upgrade has a large number of resolved cases, the firmware will be pushed to all users.
