Question about AC180P Charging Station and Gas Boiler Connection
I have an AC180P charging station to which a gas boiler is connected. The boiler requires a neutral wire for ignition to function properly.
The charging station outputs two phases (or is there a more accurate term for this?). I take the neutral from the grid and connect it to one of the phases from the charging station. After this, the boiler operates correctly, but a new problem arises.
The AC180P charges in standard mode at about 1kW. The boiler consumption is around 50W. However, with the neutral connection setup and the boiler connected (in UPS mode), it shows a charge of 1.5kW and a consumption of 500W. I understand that one of the phases from the charging station’s output is going to the charging input. What can be done in this situation?
Additionally, when it is fully charged, it goes into error E013.
ARM v2089.02
DSP v2088.02
BMS v1039.01
P.S. Previously, I lived with the EB70 for two years and used this connection scheme without any errors or problems.
