Ac1800 inverter
Hi all from reading posts and various other articles I’m after advice.
I have bought an ac1800 and pv200s solar panel’s not used yet.
Living in Wales and spending our holidays in uk solar charging will be an issue a lot of the time due to rain etc.
I understand I can charge through the cigarette lighter at a slow rate limited by the wiring volts and fuse size etc.
I don’t really want to install an inverter connected to the battery and run through the fire wall, I know my limitations, I only change fuses, bulbs and tyres.
I understand an inverter would need to be pure sine wave is there one anyone knows of that I could plug into the cigarette socket just to increase the charge a bit while driving to or between sites.
Yor cigarette socket is the limitation regardless of direct to the AC180 or to an inverter. It won’t increase the wattage capacity input.
As @Mandp already mentioned. There is no difference between using the 12V Outlet directly or plug in a 12V DC to AC 110/120/230/240V Inverter into it. The maximum draw is about 120W to 130W. A Inverter might make things even worse, because while switching from DC to AC there is also a certain energy loss
I was afraid that was going to be the answer. At least I can put that out of my mind now and just accept the charge I get.
Thank you for the advice
I appreciate your help I guess the option I have is buy an eb3a as an additional power supply if necessary.
Thanks for your help and quick reply.
My bluetti pv200 is 26v so when I charge through it I will be limited to 8amp.
If I buy a 2nd identical pv200 I understand that I create what I think is called a daisy chain connection. Will that then give me the approx 52v to increase to 10amp etc.
Thats correct. The Powerstation dont charge with full amps at any time. There is a range where it doesnt reach the full 10 amps while charging
“Daisy Chain” is not the best description. There are 3 ways to connect solar panels; (Example is for 2 or more panels of the same size)
  1. Parallel - This is where both Positive (+) and Negative (-) are connected together. The math for output is; Add the Amps output and use the lowest panel voltage if different sizes. i.e. 26V @ 20A.
  2. Series - Here you connect panel 1 + to panel 2 - and then panel 1 - and panel 2 + to the Bluetti. The math here is to Add the voltages and use the lowest of the rated Amps of the 2 panels. i.e. 52V @ 10A. This is the one you should use.
  3. Not applicable, but the 3rd option is a combination of options 1 & 2. Here you use 4 panels, 2 sets each connected in series and then connect the 2 sets together in parallel. Or 2 in parallel, then connected in series. The output in Watts is the same.
In series 2 x PV200 have a Vmp of 20.5V each and an Imp of 9.7A. So, 20.5 x 2 = 41V, then multiply by 9.7 = 397.7W. This is perfect conditions, On a summer day in the U.K. expect 70-80% of this and in overcast conditions, much less. More…
I’m actually out prospecting in my caravan in Victoria, Australia and it’s winter here. I have 460W total solar, 2 x 150W angled solar matts and 1 x 160W on roof horizontal all in parallel as my caravan controller will take 30A.
When the winter sun shines, I get 23Amps on the display, around 400W. Yesterday was overcast and rainy and I was lucky to get 6A = around 100W.
We get a lot more Vitamin S in Oz than the U.K. gets. (Sunshine). I qualify that statement as I grew up in England and migrated here many years ago. :) So don’t expect any better and probably less…
PS. Just checked my display, it’s 0915 in the morning, sun is shining and getting 8Amps already.
