AC180 Variable charge option?
I have an ac180 connected to an inverter and the inverter (1500w with 3000w peak) is connected to my car battery. I’ve set it up so only when i drive the ac180 will charge itself.
Would it be possible to change the 3 charge options into something more variable?
Right now there is silent mode wich is ±300W
Standard mode wich is ±1100W
and turbo YEEET ±1400W
But for my setup 800W would be the sweet spot. I know the ecoflow delta 2 has this option available.
So if there would be an custom option where i could limit the income that would be cool. I think a lot of campers buy the delta2 because of this function…
@GeoffreyV May I know your AC180 SN and DSP versions?
This way I can have the technicians see if it’s possible to upgrade to allow adjustable standard charging power.
So here’s the info you need!
SN: 2410020662661
DSP: V2126.02
@BLUETTI I don’t know if I have to tag you as well, but here you go!
Thank you for providing the information.
Unfortunately, after confirmation, the DSP version of this batch currently does not support adjusting the standard charging power.
I have already forwarded your suggestion to the relevant firmware responsible person.
Oh, sad :( would’ve helped me a lot for my roadtrips or jus in general car use… Thx for checking!
I just received an AC180 from Bluetti with DSP version v2102.02 App says I’m up-to-date. S/N 2417003522xxx.
Where does that leave me re: the ability to adjust SoC limits? I’m using it as a UPS for my main workstation, server & network gear and am concerned about keeping the unit always at 100% SoC. Still, vastly superior to the lead-acid systems we’ve been stuck with for years.
Any updates? Will it be possible in the future via and software update? Or is this something that’s never going to happen? Would love to see my bluetti charge at 800watts while driving…
Hello
Any updates about this? @BLUETTI
@apulidoc99 After confirming the tech team, the custom charging power feature is currently not supported.
@GeoffreyV I would recommend that you purchase a Charger1 so that you can maximize efficient AC180 charging while driving.
@BLUETTI
I need my “standard” charging mode to be 850w as my wall outlet protections are limited to that. I know I could use silent mode but thats too slow some times. And when i need to charge it faster I could go somewhere else and use the turbo at 1440w.
Let me know what can we do.
Since the standard charging requires 1000W, if your outlet has limitations, it can’t charge at full power.
Or could you provide me with your AC180 serial number (SN) and software version? I can check with our technical team to see if there’s a firmware update available
SN is AC1802452002537535
DSP is v2102.04
