for all the help and suggestions! I checked everything you mentioned. My grid power is 240V & 50Hz. I also made sure the firmware was up to date in the app.
In the App settings, I confirmed the power frequency, turned Eco Mode OFF, and checked that Grid Adaption was OFF . I also switched the charging mode to Silent, since my load is only around 20-30W. That alone seemed to make a big difference. It’s been two days now without the main RCD tripping.
When I say “tripping”, I mean the main house RCD (differential) going down, not a branch circuit breaker. The Bluetti was plugged directly into the wall, and from its AC outlet I had an extension board powering low-load devices (router, PoE switch, Home Assistant Yellow, house alarm, etc.) - about eight devices total.
The setup was intended to work inline like a UPS. That is, the Bluetti stays at 100%, passes power through, and switches to battery when the mains go out, then back to charging once power returns. That worked perfectly until a couple of weeks ago, when the RCD started tripping several times a day.
I later disconnected the Bluetti and ran the same extension board directly from the mains to test it, and the RCD stayed stable. Around the same time, I had an electrician here doing some outdoor work, so I asked him to have a look. He ran a few tests on the panel, found that the existing RCD was very sensitive to inverter-type loads, and replaced it with a Type A differential.
Since then, the battery is plugged back into the mains, and the extension board into the AC outlet, and everything has been completely stable, no more trips.
