Does the AC180 have a blocking diode built in to prevent battery discharge back through the solar panels at night?
That’s pretty much a given for ALL solar gear today. It was only in the early days before anyone knew better ![]()
@Mark1
Our solar panels are equipped with anti-reverse current diodes (when connected in series).
And the generator has an internal anti-reverse function, there is no way to charge with the positive and negative poles reversed.
