AC180 SOC goes to 0% when battery charge is around 60-70%
I’ve got a new AC180 that I fully charged only one time after its purchase. I was never able to drain completely its battery because SOC goes suddenly to 0% around 60-70% battery reading on the status display. What is strange indeed is that it goes to full SOC 100% again with only a 45 min recharge (in silent mode around 300 w/hour). It sounds like the battery is faulty or with a reduced capacity. This is happening even with the recent available firmware both for the station and the battery pack software version. Here are more details about it:
AC180 SN 2313000924597
ARM v2074.05
DSP v2078.05
BMS v 1033.06
The power station is only 1 month old with very few hours of workload (mainly connected to my PCs for a max 100 w/h output)
Is there anyone with same issue?
Thank you
@civarx Please try to do several cycles of charge and discharge (empty the battery and fully charge it without interruption) to correct the SOC.
Hi and thank you for your answer. I have informed Bluetti technical department through sale.it@bluettipower.com some days ago: they said the same thing and I have completed 3 discharge test and informed them. The problem is that a FULL discharge cycle through an electrical appliance attached to the AC180 is clearly impossibile because during these tests unit has gone from 100% to nearly 94% charge status and then suddenly switch to 0% SOC status after nearly 45 min of power usage from a small portable PC with a mean 30 w/hour energy absorption. Every recharge cycle to get it to full power only last accordingly 40-45 mins (unit in reverse went from 0% SOC status to 94% and immediately 100%). Anyway It is not working as it should: hoping support will contact me again offering a unit replacement because it is only 1 month old!
@civarx
Is the charge and discharge cycle done in the following way?
  1. Disconnect all loads, without any charging.
  2. Discharge until AC180 was automatically shutdown (suggest loading a device with 300-400W or more)
  3. Disconnect all loads, and then fully charge AC180 via AC. (automatically stop charging).
If the cycles can’t solve the problem, please provide me with your order number, then I will contact the CS department to help you to exchange.
ok, I will give a try with what you suggested about the discharge output of 300-400 W and let you Know then. There was not a specific indication in my ticket opened with sale.it@bluettipower (ticket number is ## 21470 ##) about recommended rate of discharge. Thanks you
@civarx Hi, is there any updates?
Hi, bad news…I have tried to charge it again today but the unit seems completely dead: display barely lights up when I push the on/of button and unit switches itself off almost immediately: this happen with unit even connected to AC power source through the cable. No errors or whatsoever on the display when it comes to life. I think there is a major hardware problem at this point: in the meantime I have not received a reply of my recent posts with the assistance for the ticket opened through sale.it@bluettipower (see above for the ticket reference). Here is some more details about my order ID and AC180 Serial Number (the one I read on a white label with bar code on the bottom side of the unit). Order ID: #SPF-IT5006 , AC180 SN: 30076QE23120205. Could you help me with the support for a unit exchange or for an answer from them about my reply of some days ago? Thank you.
@civarx Thank you for your information. They will contact you via email ASAP.
good news, thank you very much
Hi, just to inform you that today my AC180 has been collected by the pick service set up by Bluetti Customer Service. The merchandise is on its way to your depot. Big thumb up for CS so far. Thank you again!
Good You got it solved, message us how long whole replace took and were there any problems or not. I look forward to ac180p or o. Future ac180max as my next unit, so every news about is ot faulty or not is interesting
I will Keep the community informed: my unit was a pre-sale order so it may be affected by technical troubles related to the very first unit generation, which can occur with other tech products too in general. Anyway, the CS has proved to be professional at the moment. Let see how it will develop.
Hi all, as promised…this is an update about customer service related to my issue. Big thumb for their support so far: my old AC180 was picked up around mid of July directly from my home (logistic service was set up from Bluetti customer care at their expense). A new AC180 was sent as a replacement and it has just arrived today at my home. Next hours and days I am going to test again (obviuosly after a full recharge cycle as recommended in the manual).
Thank you for the update. Looking forward to your test results.
Hi, this is my first post. I’m having the same problem with my AC180 and will follow the recommendations outlined in this thread.
Hi all,
Following up on my earlier post in this thread. I’ve now completed the 3 full discharge–charge cycles as Bluetti recommends (down to 0 %, rest ~2 h, then charge to 100 % without interruptions). Firmware and BMS are fully updated.
Unfortunately, the problem has not improved. In fact, it’s worse. I did a test with a stable ~1 715 W resistive load (an iron) and measured that the AC180 dropped from 100 % to 0 % SOC in just 16 seconds.
According to Bluetti’s own formula it should last about 30 minutes. That’s over 99 % difference from the expected performance.
I’ve made a detailed technical report and video which I’ve already shared with Bluetti Spain’s support email (no real answer yet, only automated acknowledgment).
I’m sharing this here so other users can see the specific numbers, and in case anyone has seen the same extreme SOC jumps even after the recommended calibration cycles.
Also hoping any Bluetti staff here might see this and help escalate the ticket.
If anyone is interested I can share the video link or more details.
Thanks in advance!
Absolutely take advantage of the 5 year manufacturer warranty to repair your unit if applicable. This is provided you bought from Bluetti directly or through an authorized provider such as Amazon. Depending on time of service/purchase date you may need to work through Amazon first before Bluetti will step in, but every AC180 sold by Bluetti is still under warranty because its only 2 years old and the warranty is 5 years. I believe they even pay to have it shipped for repair.
Thanks for the tip! I bought it from an authorized seller (Leroy Merlin Spain) and I’m already in contact with Bluetti support.
I’ll follow up with them, and it’s good to know about the shipping coverage.
Yesterday (12-08-2025) my unit finally arrived at Bluetti’s technical facility, after being held for several days at intermediate DPD locations.
Customer support has confirmed that the repair will now begin, with an estimated maximum lead time of 5 working days.
I’m still opting for the repair of my original unit — practically new and with very little use — rather than accepting a refurbished replacement.
I’ll keep the thread updated with any new developments.
The technical team has completed testing and determined that the battery cells in my unit have failed beyond repair. Bluetti has confirmed they will send me a new AC180 within two business days. I have requested written confirmation that the replacement will be new (not refurbished), with full warranty, and details about any technical improvements to avoid the same issue in the future. It would be interesting to know if other owners have experienced similar failures, or if this was just an isolated case.
Update (continued): Customer support has now confirmed that the replacement will be a brand-new AC180, not refurbished, with a full 5-year factory warranty starting from the shipping date. They state that the unit will be from the most recent production batch and that my original failure was an isolated battery cell issue, not a design defect. They also mention that each batch undergoes quality checks to minimise the chance of faults.
