I have an AC180 that keeps showing a short after a few days, ECO is turned off and I’m thinking of returning it because its only 10 days old.
Firmware is up to date
Any tips before I return it?
Hi @crumbym
did you leave the unit for a moment and check if the error still persists?
Mostly the error will fix itself after a while, like a day.
You also could try to turn on the unit and if the error still is there, press the off button for a longer time, like 10 seconds to discharge all capacitors.
