When the PV and AC inputs are charged simultaneously at AC180, the PV input amount is subtracted from the AC input amount. why is that?
SN 2317001118744
thank you
@jack893 Did you open silence mode? Under silent mode, if the PV and AC inputs are charged simultaneously at AC180, PV is given priority, and the rest is provided by AC inputs.
@BLUETTI_CARE This is silent mode.
I want to enter the total value of the actual PV and AC input power.
Car charge requires MAX300w input in silent mode.
AC charged in silent mode. I attached a watt meter to the wall outlet and measured the charging power. It was an output of 170w . At the same time the display power indication for AC180 was 260w. Why is it not displaying the true value?
@BLUETTI_CARE AC input power in silent mode displayed x1.6 times higher than it actually is. Any solution?
