Hi,
I have this odd bug where the AC mode does not display consumption below ~15watts, it just shows 0w.
If I switch the load over to the DC ports, or add more load above 15w everything operates as normal. However, below ~15watts it does not display any consumption is taking place? It occasionally will flash 15w output, then immediately flash back off to 0w.
My small EcoFlow river is able to perform this task perfectly and it is really frustrating because I like to use this function for many reasons!
Thanks for the reply, Ill see if I can find that.
However, I definitely don’t feel this SHOULD be considered normal behaviour. Either a case of poor hardware design that isn’t able to provide granular enough resolution for hardware that will potentially (I’d say even likely given the camping/outdoor focused use) be used for lower wattage appliances, or a software issue that would need refinement.
The “eco mode” literally can be set to switch off the unit at 15w, so having poor resolution around this range is a pretty crap design if that is the case.
My AC180 showed usage at 8 watts for a couple of weeks. After I did a software update it stopped showing low wattage usage. Trying to figure out what caused the problem. I hate that I updated my software now.
if your not satisfy with a specific software version, you can roll back some firmwares or install a test firmware. In both cases, @BLUETTI_CARE can you help?
@Pampa If the AC output is less than 15W, then the power will not be displayed on the screen. If it is DC output, even 1W will be displayed. Is it possible that you saw the output on the DC side before?
I saw it again the other day. Only flashed the low wattage amount for a couple of seconds and then went back to zero watts being used. I know the light bulb is requiring 8 watts. I assume the light fixture is using something. I’ve been tracking how much energy the Bluetti is using in my home because I want to know what to expect if we have bad weather. I put the usage down for 10 watts. Hope my estimate is close to correct.
