I just purchased an AC180 and a PV200 (20.5V / 9.7A). I already had a 100w panel 18.9V / 5.81A. As I understand it, I could tie these in series or parallel.
If I tied them in series, I would get 39.8V / 5.81A for 231W.
If I tied them in parallel, I would get 18.9V / 15.51A for 293W … but does the AC180 limit amps to 10A, so I would only get 18.9V / 10A for 189W?
If parallel would only provide 189W, I might as well just run with the PV200 for 200W (231W running mismatched panels in series not worth the effort).
Do I understand this correctly?
Thanks in advance, Keith
You understand correctly and often when panels are badly mismatched it makes no sense to run them. The amperage limit is usually the weak point limiting input wattage.
I just read that the AC180 solar charge port limits the Amps to 8A when the voltage coming in is under 32v. That means a PV200 by itself (that has a 20.5V, 9.7A) will be limited to 8A, giving it a max charge rate of 164watts (8x20.5). I might try putting that small 100w (18.9v, 5.81A) panel in series with it. That would provide 39.3v and 5.81A for a total of around 220w; quite a bit better than the 164w that a PV200 by itself will be limited to.
