AC180 feels like it has half the capacity
I’m having this problem where my AC180 gets to 50%, it would go straight to 0% and shuts off. When charging, it would charge normal from 0 to 40%. Then it’ll go from 40 to 100% in minutes. It’ll stop charging once it gets to 100%. I’ve tried to recalibrate the SOC by discharging to 0% and recharging to 100% four times now and the same pattern above persists. It feels like I got half the capacity it should now. Wondering if anyone have this issue and if there was a fix? Purchased 8/23. I see people have newer firmware but my app says everything is up to date.
S/N: 2328000492684
ARM v2073.04
DSP v2077.06
BMS v1033.12
Hi @manng, Thank you for getting back to us so quickly.
We have requested to push the latest BMS firmware for you.
Our IT department will push the latest firmware to your unit in 24 hours.
After that, please try to complete the cycle of discharge and charge to correct the SOC. The problem will be resolved.
  1. Please discharge all the power (charge AC & DC appliances with the power station) until the SOC is 0%, turn off the machine, and leave it for 3 hours till it cools down.
  2. Please charge it again, please do not load any device when charging it, and do not interrupt it while charging.
If not, please contact us for further service.
