AC180 BMS error EO74
I have had the AC180 for a few weeks and it was working fine until the temp light came on with AC outlet about 1500 watts and it would not charge, The BMS fault code came up as EO74 BMS error. I have since got charge and updated BMS, my concern is that the fan was not running when using ac before the update and now it is,
Does anyone know if I had an original fault of no fan which caused the temp error, and now it is updated it is normal for the fan to come on with AC. The unit is working ok but I am not sure if I can rely on it if it is not operating correctly. I am having trouble getting any answers from Bluetti.
@Tom1 Could you please check the exact error code about the battery pack below
There’s no error code … the error code was EO74. BMS it is gone now
BMS version v1033.12
@Tom1 Normally, it may be caused by temperature issues. Once the temperature returns to normal, the error code will disappear.
So, I have an AC2A and last night while I was using my mini CPAP I noticed that it was shutting down power flow to the AC side causing my CPAP to fail. Once the error cleared it would begin functioning again. This happened a dozen times before i finally switched over to the other brand generator I also have.
When I looked up the error, it showed the E074 code and while researching I found this thread.
Here’s my configuration:
AC2A connected to the AC port of a different brand but higher capacity solar generator. Effiectively putting it in “Grid Mode”.
Firmware and software all up to date as of today’s date according to the app.
Temprature inside the Jeep that i was sleeping in was 40F-46F. These temps weren’t even that extreme.
One thing I do notice is that while in pass through mode there is 000w showing on input and output of my unit. (Is the AC2A incapable of measuring flow through it while in “grid” mode?)
Thank you.
-Dan
I recently connected my new Elite 200 V2 and Charger 1. Worked like a charm.
However, today I was connecting to a new PV solar panel, and got the alarm/error E074. I also will note there was a blue thermometer, indicating low temperature. I left the unit overnight in my vehicle and it was ~ -2° C.
Quick fix to warm the unit, was to boil a kettle of water from the AC output… it drew ~ 1,450 W and boiled without issue. Once things warmed up, the PV started charging fine.
I will also note that I had connected the unit to the grid power, when it was “chilly” and the same error was displayed.
Bottom line is the low/high temperature features from BMS system. Good to know, so bumping your thread to share.
Cheers
