AC180 App IoT upgrade -> 9046.04
In my app I get the message:
IoT v9046.01 → 9046.04 with the request to upgrade!
Normally before I update/upgrade my devices, I want to know in advance what has improved since the last version! Normally you can consult a changelog for this. This allows you to see what has changed and/or whether it is actually worth doing this upgrade with regard to my own device, in this case the AC180.
After all, in practice, not every update/upgrade is actually an improvement, let alone that e.g. new bugs are mistakenly added. I still work according to the golden rule: when everything works well, you shouldn’t change anything! Where can I experience more about this upgrade (changelog).
Any support is very welcome!
Hi @Bluemoon, I appreciate your interest in BLUETTI.
Yes, your suggestion is correct. If there are no issues with the current usage, there is no need to upgrade, as the upgrade process can be troublesome and we do not want to inconvenience customers.
The new IOT firmware optimizes the connection with the app in terms of strategy, making the usage process smoother. You can consider whether to upgrade based on your own experience.
At present, we indeed do not have centralized release notes for each version. I have forwarded your feedback to the development team. Thank you very much for your suggestion.
Interested in a change log as well
