I thought I would note my recent trip use of the AC70 & AC180 in my RV. I use my rig primarily for gold prospecting. Apologies for the long post, but hopefully of interest…
SETUP
Before going further, I’m in Australia, we use a different grid power to the U.S. Also, certain nouns used
to describe items differ. That said, I’ll use Au terms and (*) those that I know in U.S. speak, lol. i.e. Caravan or Van abbreviated = (RV or trailer). I’ll use W or Wh for AC items and A or Ah for nominal 12VDC.
My caravan is a small single axle, off road pop top, with combined loo (toilet) and shower. It has a 110lt compressor fridge and a 30lt drawer fridge accessed from outside, which is rarely used.
Also, a 700W microwave, all LED lighting and the TV is on 12VDC all of the time even tho’ I have a VAC power brick. FYI, we use 240VAC at 50Hz and that is the output of the Bluetti power banks. The van has a 160W on roof horizontal only solar panel and the battery management system is a combined unit that provides; 30A from 240VAC supply, inbuilt 30A max MPPT solar controller and a voltage sensing relay for vehicle charging.
I was not happy with this method of DC charge and have disconnected that input and rerouted it to a Redarc BCDC1225n Lithium profile DC-DC charger. I fitted 2 x 100Ah LiFePo4s when I bought the van, replacing a 100Ah AGM as all chargers have a Li profile. I have also wired in an external plug for an additional x 150W solar mats, for a total solar input of 460W max. That’s most of the background, next post = PROCESS.
