Hey there!
i want to use one of my EP500 Pro for charging from the AC Outlet with power from my Solarpanels that are not used in goes into the grid.
You can set a max current value, which i use in the moment with a smart plug that simply tunr on when value x is reached and turned off when no power goes to the publich grid anymore.
The only problem is that everytime the plug cut the power on goes back online a relay is clicking inside the pro. So cant be that great if its turn on and off everytime.
Im searching for a solution where a plug can read the current power that goes to grid from HomeAssistant software and regulate the Power to the EP500.
Any Ideas?
