Hello, after connected to bluetooth, the display no longer turns off and is on the brightest level. I can’t do anything either…
@Floh Are you referring to the AC200MAX?
If you could describe the problem more specifically, It will be easier for our @BLUETTI_CARE team to assist you better.
Hello Bluetti…the simple one is so close…I did a reboot and all is ok…thanks
