if it stays on at night and supplies energy, the solar recharge does not start in the morning, I have to turn off AC300 to start the solar recharge
if I leave it on at night, but without load, after a few hours it loses the wifi connection, but in the morning it starts charging from the solar and the wifi connection resumes
ECO mode is off
for the rest I can charge it with my roof panels using the D300S which gives me 1.4 kwatt when the sun is out
Thanks for the question , no, it is set to PV Priority UPS, but the problem I had even when it was on Standard UPS, already as soon as it was removed from the box it had this problem
@Thang You also used the D300S right?
If so, are the D300S and solar panels grounded? If grounded, try not grounding them and see if you still need to reboot the D300S in the morning to get normal input.
Did you reconnect to WiFi after shutting it down at night? does the WiFi connect properly?
