@BLUETTI_CARE my Ac-200p keeps giving me the Fault code 01 041, The fault happens with Zero draw on the battery early in the morning. Is there a fix for this?
Hi @plamer, This error code indicates a temperature anomaly.
Please check if the environmental temperature around the AC200P is too high or too low.
Meanwhile, please stop charging and disconnect all loads. Turn off the unit and place it in a suitable temperature environment for 3 hours before turning it back on and using it again.
Does this help?
