AC 180 discharging
Hi everyone.
Bought my unit AC180 6 months ago and manual says it should be discharged and charged again at this stage.
I have not used the unit at all and it still stored with the 60% recommended charge.
Could you advice what’s be the best way to discharge it, please?
Many thanks.
Hi @Archyman, If you haven’t used the AC180 for 6 months but it still maintains 60% charge, it indicates that the AC180 is in good condition. Please try powering your appliances to see if there is any issue with rapid discharge.
If everything works fine, recalibration is not necessary.
However, if you plan to prepare it for emergency use soon, or if you suspect there is an issue with inaccurate SOC or fast discharge, please recalibrate it, which involves a full discharge and recharge cycle.
  1. Please discharge all the power (charge AC & DC appliances with the power station) until the SOC is 0%, turn off the machine, and leave it for 3 hours till it cools down.
  2. Please charge it again, please do not load any device when charging it, and do not interrupt it while in charge.
Please feel free to contact us if you need more help.
