My AC 180 has suddenly stopped accepting charge on the DC input. There are no firmware up grades available. I don’t know what to do as I rely on it charging as I drive.
@Carol68 It would help if you describe how you have been charging your 180 when driving. i.e. source, voltage amps etc. We can’t read minds, lol.
If you have exceeded the 60VDC input voltage, this could be the reason. Another thing to check is any fuses in the charging circuit, it may have blown. A further check would be to try a different DC charging source, this will point to either a source issue or the power station.
Hi, it’s from a BLUETTI charger set at 56 volts or solar max 150 watts. I’m in contact with support, thanks
