I know the AC500 is set up for up to 6 B300s batteries.
Is the limit because of hardware, software, or both.
I’m already bumping up against the limit of battery power at night. The only way forward is to buy another AC500 and batteries.
If a 7th B300s is plugged in, would it simply not connect, or would alarms start going off and it all shuts down?
Is there any chance down the road you could make this happen with a software change, or do hardware limits get in the way?
I would say its more like a physical issue. The B300S Packs are connected parallel. Which means that the current rises witch each battery pack you connect. I just would assume, that the cables arent thick enough for seven batteries. But maybe im complete wrong. Just a assumption.
The technical team stated:
When connecting more than 6 battery packs, it may work normally, but the system can only recognize 6 battery packs.
However, since it has not been tested, this condition is unpredictable, as the number of each pack is changing.
