I would like to suggest a couple improvements to the app that could be used to add powerful
functionality to the AC200L.
You should add two user programmable settings to the AC200L:
- max discharge limit - for both the main battery and any extension batteries connected
 (a sticky setting that would stay set even after changing expansion batteries)
- discharge source preference - one of three: MAIN (AC200L), EXPANSION or BALANCED
 (I would like to be able to draw power ONLY from an expansion battery until it
 reaches the max discharge limit set above, then have power drawn from the main
 battery until I switch expansion batteries, when power would again be
 drawn ONLY from the expansion battery. That way I can recharge one expansion battery
 while the other is being discharged, and only have the main battery on the AC200L being
 discharged for short periods until I can change expansion batteries.)
