A new version of the AC180 or not?
I have a AC180 and know that a B230 can be plugged into it’s DC/PV input with the right cable.
While on ebay, I came across this. A AC180 & B230 or B300 attached with what looks like the same cable used by the AC200MAX and B230.
I double checked my AC180 and there is no plug on the left side. Is this a new version of the AC180 or did someone photoshop this?
It shows to be sold by “bluetti US”, which I think I’ve bought stuff from before.
You don’t say where you are, lol. I’m in Oz and here there is only the original AC180 sold at this time, I have one. There is an AC180P sold in the U.S. with a larger battery Wh and physical size.
I believe that at a recent tech show in the U.S. a further version was exhibited, not sure but, noted as an AC180T with hot swap battery packs. It appears that there is a lag for new products to hit markets outside of the U.S. :slight_smile:
This is in the US.
Looking at bluetti.com they show a AC180 and AC180P. Both includes images of the left side, and neither show a port for this.
@rgb Hi Richard,
AC180 does not have battery pack expansion function, and can only be used as a power bank mode. Whereas AC200Max can be expanded with B230. The cables used for these two are also different.
When B230 is used in power bank mode, it needs to use P090D-7909. The cable used for AC200MAX and B230 is P090A.
I already knew all that since I have a AC180, AC200MAX and B230.
Did you see the picture? It shows the same cable used between the AC200MAX and B230 being used between a AC180 and B230. Why?
@rgb
Sorry for misunderstanding and confusion.
Yes, there is no battery connection port on the side of the AC180. The battery pack can only be connected in the way shown below.
Thank you for pointing that out. I have informed the eBay department to request them to modify the picture as soon as possible.
Thank you.
I’m sure anyone buying based on that picture would be disappointed.
@rgb good catch Richard! Its been updated on ebay and fixed the incorrect image.
AC180 does not have a battery pack expansion function…Whereas AC200Max can be expanded with B230
That same ebay listing mentions "
  • Worry about running out of juice on your way to the next destination? Get your AC180 charged via expansion batteries
  • B80 (806Wh), B230 (2048Wh), and B300 (3072Wh) - to ensure a continuous power source of up to 4,224Wh,
  • which is sufficient to last your outdoor fun even longer.
…And I read something similar when I bought mine.
So is that wrong, and the AC180 can’t be expanded (with a B230)? Or are we talking about some specific way that the AC200Max can be expanded that the AC180 doesn’t support? If so, what’s the difference?
@ischorr This description refers to the power bank mode of the AC180 when connected to the battery pack.
@BLUETTI Correction, Power Bank mode is what the B80 expansion battery is set to when using with the AC180, the AC180 does not have a power bank mode. :grin:
The input to the AC180 is not via an expansion port, as it doesn’t have one.
To connect to the AC180, an optional cable is required, which has a connector to the B80 output on one end and a D7909 barrel connector on the other. This goes into the AC180s DC input port at the limit of 12 - 60VDC and 10A max.
The B80 in power bank mode has an output of 25.2V @ 200W. This means at this voltage your input will be 25.2V @ 8A due to the lower voltage = 200W.
Added to the above, this is why I chose to buy the Charger 1. Here, I connect a 100Ah LFP deep cycle battery to the input of the Charger 1, then the output to the AC180 DC input port.
With the Charger 1 set to 50VDC output, I get a full 500W charge to the same input port as it’s 50V x 10A = 500W.
Hi @Mandp, don’t own a Charger 1 however can I ask you this, could you connect a B80 in Power Bank Mode into the Charger 1 input, and by setting the output of the Charger 1 to 50V, get 500W? Just wanting to make sure I understand what you are saying. Cheers.
NO - As mentioned, the B80s output is 200W regardless of voltage or amperage, that’s all it produces. The Charger 1 won’t create power, it just converts, outputs to similar wattage by manipulating the output voltage, if not a little less due to system consumption.
The Math if you have 50V @ 10A Charger 1 output - its input is 500W @ 12V is 41.7A and that is the load on the alternator. If you reduce the output voltage, the input amperage will also reduce.
In my instance the 100Ah LFPs voltage is 13.1, so the current draw is 38.2A. The math will also vary according to alternator voltage and available current (A).
My 100Ah LFP has an output limit if 1C. C being its capacity, so it will output up to 100A at 13.1V = 1,300W until close to flat. This is far higher than the B80s 200W output. The limit here is the AC180, it will only draw 500W max.
To perhaps simplify this for you - A device will only draw from a power source what its maximum load is, the source won’t try shoving in the extra it could provide. Similarly if the source is low and the device has a load range (i.e. the 12-60V-10A of the AC180 which is a range of 100W to 500W) it will accept all that it is given i.e. 200W from the B80 and no more.
There is another scenario - If the load was 1,000W and not flexible (i.e. a hot water heating element) and the source was a 500W inverter or fuel generator, it is almost certain the inverter or genny will overload and shut down, almost, if not, immediately.
