420W Panels Compatible with D050S Charge Enhancer?
I have just received Bluetti 420W panels, rated @ 12 amps. Will these panels work with the D050S charge enhancer rated @ 10 amps? Will this be stressful for the enhancer? I am charging my AC 200Max. Many thanks.
Amps get “pulled” not pushed from the PV module.
You only have to stay below the input voltage limit
It will work pretty well the maximum you will get with that panel is 350 watts due to the charge enhancer limiting the panel to 10 amps. It is quite difficult to get much more out of the enhancer with a single panel though as you would require 40 volts+ and not many 400 watt panels have such a high voltage.
When I get the enhancer I plan to pair it with a 425W Trina Vertex S panel which has an operating voltage of 41.5v and maximum amperage of 10.24.
