Is there a way to boost the amperage in 220 power?
I have a motor that tries to start but shuts off. I know it is not a faulty motor just too much initial draw. I’m sure once it’s spinning the motor will run, it’s just the initial start up.
You can’t boost the bluetti amperage but you can buy a stand alone soft start device or a larger output capacity bluetti.
