2022 EB55 No Longer Charges - AC or DC
I recently found out that my EB55 display was providing bad info. It wouldn’t charge much, as it was acting full. However, I believe it was actually low in charge; critically low.
I put a load on it until the unit turned off. I have tried loads as high as 500W and as low as 10W. These were the first time I saw the display showing “bars” disappearing (for SoC), in a long time. Before, only the top bar would ever blink, every time I charged it. I routinely checked the unit to make sure it was charged, about every other week. It was at my parents’ house as a backup battery for them.
After draining the battery until it turns off, it repeatedly takes only about 30Wh of charge, with the AC charger unit before it stops taking current. I have also tried low power 50W DC charging and the result is the same (it just takes longer on average). On DC it starts at ~50W then goes down to 4-5W half the time and 0 half the time for several minutes before it once again stops taking current.
When pushing all 3 buttons, the codes displayed are:
• U150
• E000
I reached out to Bluetti support and since it’s out of warranty, they are recommending a new unit, due to shipping costs and potential cost of repair. I will do this, but I really don’t like the idea of e-wasting the EB55.
I am a ham with some experience soldering. Do you think it’s worth my time to try and open it up and swap out the batteries? I think the batteries are the problem, caused by chronic low charge as a result of the display being faulty.
Thank you,
I pulled it apart, but it’s looking pretty daunting to replace the batteries or even figure out which ones are bad, if any.
There are 6 banks and the total pack voltage is about 23.4V. This doesn’t seem too low, considering the individual batteries are rated at 3.2V and they are clustered in packs which are then in series to equal the 23.4V.
